Posted by gene bender on September 15, 2014 at 16:14:52 from (67.55.226.121):
In Reply to: tree vs super a posted by henhawk1969 on September 15, 2014 at 15:19:43:
Mite need to cut it into if its bent very much as to remove you need to take the big nut off in the end where the shaft goes then unscrew the shaft out the front. But if the shaft is bent very much it will not go thru the bushing and out the front. You can cut the shaft 6in or so before it goes into the housing and then remove it out the front. You will then need another shaft or get a coupling to refasten back together drill holes to fasten pieces to the shaft. I have some good used ones.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
