Because they used what IH called a delay lift valve. Small valve that screwed onto the cylinder or outlet to cylinder and the pressure in the system had to build up to a certain point before fluid was sent to the cylinder. May not be exact just going by memory, early ones needed between 200 and 300 PSI and later ones 400 to 500 PSI before the pressure went to the rear lift. By that time pressure was reached the front ones had raised to the end of there stroke.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
