12volts on '55 300
Posted by Wayne on January 03, 2001 at 13:21:32 from (205.188.200.26):
I want to thank everyone for the help and suggestions for converting my 1955 farmall 300 to 12volts. I re used the generator with a 12volt regulator and it does put out 12.5 to 14 volts when the belt doesn't slip (that's next). It also keeps up with the new 12volt lights. I did replace the ammeter with a volt meter. (Also ballast resistor for coil and 12v. sileniod on the starter). It starts much better now in our current Missouri cold and runs great. The new starter sileniod has the "I" terminal which I used to bypass the ballast resistor during cranking for a hotter spark. You were all great help and I look forward to checking in here from time to time. (This is my first experience with a Farmall tractor -- relatives own them, but this is my first.)
Post A Followup
: Re: 12volts on '55 300
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
