Re: IH model H, won't start
Posted by NNP on October 04, 2014 at 04:35:01 from (66.66.112.196):
In Reply to: IH model H, won't start posted by james06 on October 02, 2014 at 18:06:57:
stuck engine on a tractor that has been sitting,
means a completely stopped up carb...with rust..
Like the other posters have said, gotta try again.
Just soaking in carb cleaner won't do it with rust.
gotta break out the wires, needles, and probes.
With your symptoms, with the supply and bowl drain showing flow,
first suspect like mentioned is the main nozzle, its well, and passages. usually a rusted disaster area.
(careful here if it's a threaded in nozzle, they break easily when rusted in)
And depending on which carb design, a main jet and its passage/needle at the bottom of a carb bowl is sure to be full of rust.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
