Posted by D Slater on October 05, 2014 at 16:31:36 from (184.14.160.167):
In Reply to: Super c distributor posted by Joshua Rod on October 05, 2014 at 15:41:56:
If it turned okay before the gear change you ended up with no shaft endplay after putting the pin in the replacement gear. Or let the shaft push toward the point plate and mess the weight guard up. Also find them that someone used to long of screw in the condenser or point contact mount and mess the guard or other things under the breaker plate. If you have end play, remove points and the terminal post from the distributor. Then the 2 cap clip screws and one other from the side of the distributor. Lift the breaker plate out then check guard, springs, weights and the weight pins. Shaft can be removed from the body after the drive gear is removed.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
