you are on the right track. Remember, the carb fuel bowl MUST be full of fuel for these to run. The IHC #10 carb (which I believe to be the right number) can be VERY cantankerous. However, when they are right, they will fire right up and run......and run well.
make sure the fuel bowl is full. There should be a drain on it. crack the stopcock valve open and see if you have fuel. if you are using a gravity feed, if it is dry, the float needle valve may be stuck shut. If you have fuel, then it should fire and run.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
