Re: Steering Cup positions
Posted by Janicholson on October 10, 2014 at 13:32:41 from (199.17.6.26):
In Reply to: Steering Cup positions posted by henhawk1969 on October 10, 2014 at 11:30:02:
Steering cups is a bit of an unknown. If you refer to the adjustable ball joint, or tie rod end, then they can be serviced. Usually the ball is out of round and it might be possible to grind it spherical with care (usually not). The disks can be replaced if they are missing.
318309 and lower Serial numbers have adjustable rod ends on both. If above that # the rod ends are not adjustable. The non adjustable ends appear to be available. You will need to have the others repaired, or components made. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
