Did it go together easily. It is problematic to get the main shaft pilot bearing to enter the TA output shaft and you may have damaged it. That could cause your problem. I always put tractor in 4th gear to hold shaft up , rubber band the pilot bearing and turn input shaft through TA while getting pilot bearing started into shaft. Plus, want no help pushing it together as that only causes problems. On tractors with belt pulley cover it is easy to see what is going on but with the blind hole on that one and like a 656 it is more difficult. Hopefully this isn't your problem but it is suspect. I would take cover off TA and check for freedom of movement of planet gears wit TA lever back and clutch held down.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
