Posted by NateB on October 28, 2014 at 00:06:50 from (199.120.81.60):
I have a 44 M with a M & W 201PX live pump and a right angle Delco Remy distributor and have an odd problem.
Last winter while pushing snow I could not keep the tractor running- seemed like it was starving for gas so I spent a bunch of time checking the carb to no avail. Finally discovered the distributor was full of oil and fouling the points. I cleaned the distributor up and it ran fine.
I used the tractor in the spring to grade the driveway and had the same problem- much quicker diagnosis this time! Figured the seal on the distributor was failing so instead of using oil to lube the distributor I used grease hoping it would be thick enough not to work past the seal.
Tractor ran fine and used it a few times with no problems until yesterday- same problem!
It was not grease in the distributor so I am guessing it has to be hydraulic oil.
Anyone have any insight? Is this a seal problem or do I have a major leak inside the pump that is pushing pressurized oil past the seals? Are there parts available for the M & W pumps? I searched on-line with no luck.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
