Posted by Janicholson on October 30, 2014 at 08:58:39 from (199.17.6.160):
In Reply to: Super H distributor posted by chuckj1954 on October 30, 2014 at 08:35:20:
Were it mine, I would put the shaft (apart) in a good lathe and use a dial indicator th assess the lobe geometry. (bent or worn or made wrong to begin with) If the squareness is OK, but off center, it will never give reasonable results. If the cam is actually off center, the magnet that fits on the cam will also be off center and thus have variable distance to the pickup module. Finding a different cam shaft should be pretty easy even a worn shaft that is evenly dimensioned from centerline, (try Bates Equipment in Indiana) will be OK for replacement with an electronic system (this site has them for 6v Pos or Neg ground) It will run so much better when timed correctly on each cylinder that it will be a miracle. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
