Posted by charlie M on October 31, 2014 at 15:31:45 from (50.48.196.193):
When I bought my Loboy 184 a few weeks ago it cranked over fine from the switch. The it got to where it wouldn't start from the switch but cranked over fine by running a jumper cable from the batter straight to the starter so because of that I'm assuming the battery is OK. When I turn the key the starter solenoid just clicks like a lot battery. Checked it out tonight with a volt meter and I only have 6 volts coming from the switch to the solenoid. Its a 12 v system and have 12 volts at the wire going to the switch.Can a bad ignition switch drop the voltage that much. I don't find a voltage drop anywhere else I check. It does have a safety switch on the clutch but when the clutch is not depressed there is no voltage as one would expect.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
