Re: max. rpm
Posted by gene bender on November 03, 2014 at 06:33:21 from (67.55.226.121):
In Reply to: max. rpm posted by Fire50 on November 03, 2014 at 05:55:23:
Wit the engine off remove the clevis pin going to the carb. Now open hand throttle then adjust the clevis holding the throttle rod going to the carb wide open. The clevis probalbly will be hard to turn and you should remove that rod from the carb so you can get the clevis to turn free and easy. If then you want more RPMs turn the cap screw on top of the gov housing out. That should solve your problem unless the gov spring in the gov is broke.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
