What I found was the fingers on the pressure plate were out of adjustment. The tips of the fingers were too close to the pressure plate.
When I pushed the clutch pedal in part way the clutch would release.
When I pushed the clutch pedal all the way in it would grind.
The yoke that holds the throwout bearing was pushed too far forward and hitting the adjustment screws on the pressure plate fingers.
I had to adjust the pressure plate fingers out away from the pressure plate.
If that's what you have going on you'll need a 1/4" drive ratchet with a flat screwdriver bit in a 1/4" socket. And an end wrench for the locknuts.
I took a piece of wire and bent an L on one end that was 1-1/4" long. That way I could stick the wire up in there and use it for a gauge to measure clutch finger height.
It wasn't much fun laying on my back and working thru that little hole in the bellhousing.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
