Probably most folk that turn wrenches got an expensive lesson in "shop rate/rape" before they took up DIY in earnest. If I hadn't been part Scott and prone to taking things apart from about age 4, I probably would have done the same.
I don't fault anyone for making that mistake once, or for getting a dealer fix out of dire necessity. No one with a lick of mechanical aptitude willingly repeats the mistake. Mechanical work is only the basis of rocket science: most threads turn right to tighten; if tight is important, a torque wrench is your friend; keep enclosed things clean inside, keep moving things lubed often; fix little problems before they get big. All the rest of the details can be found in an I&T manual.
I truly feel for the OP, but for anyone else thinking about "sending it to the dealer for some noise": $4,300 buys a lot of tools, including jacks, stands, a descent compressor for an air wrench, and easily leaves enough for $1,000 for bearings and seals, and possible even some custom machining.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
