It has been quite a while since I had one of them in pieces, so I need to say AS I RECALL. Others will be along and confirm correct.
The seal is pressed into the cover from the inner side, so the cover needs to come off. The pulley MAY have a setscrew to remove first (if some early A parts have migrated onto it). In any case, the pulley will be hard to pull off. You will need to back up the pulley with a large bearing separator. Screw a bolt into the end of the crankshaft (until it bottoms) to push against. The pulley may have a groove worn from the old seal. If so, ready sleeves are available to provide a new seal surface. I believe Case-IH has seals packaged with a wear sleeve. When you install the front cover, leave the bolts loose so the seal can self-center when the pulley is installed. Tighten the cover after installing the pulley. The pulley goes on much easier if you warm it first. A toaster oven set at about 250 works well, as does letting it sit in boiling water or heated oil. Screw some all-thread into the front of the crankshaft and use appropriate plates/washers and a nut to pull it on.
You can search for past posts with more details/suggestions on removing the pulley.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
