Re: farmall 200 overcharging
Posted by John T on November 17, 2014 at 15:39:52 from (216.249.72.121):
In Reply to: farmall 200 overcharging posted by Ramp;W on November 17, 2014 at 15:25:48:
1) If it has a Voltage Regulator and its field current control relay points are stuck closed, that could cause it. (I don't think it has a Low High headlight charge control system (but Ive seen all sorts of farmer modifications out there), but if it was always in high that can cause it or the wires shorted coming from FLD on genny
2) If the wire from FLD on Genny to FLD on VR was shorted out, another possible cause.
3) If the gennys Field is shorted near its output (wires to FLD Post inside) or if the FLD post was overtightened cracking the insulation causing it to short, that may cause it, or simply the wire from FLD is shorted somewhere.
4) Sure the battery itself is okay with no bad or shorted cells.
5) Theres more but its supper time yayyyyyyy
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
