Posted by Janicholson on November 21, 2014 at 21:25:43 from (74.60.94.18):
In Reply to: Snow plow posted by grumpydaniel on November 21, 2014 at 18:05:56:
Tractor electrical systems are very noisy. Manufacturers made no attempt to shield or dampen spikes in voltage caused by ignition or other systems. Digital meters read samples of voltage on a very short time window. The sample can be taken when the ignition sends a peak voltage of 200 volts into the wires, or it could be sampled between alternator pulses of output and read voltage showing no charging. A expensive digital can filter and average these spikes. Most cannot. Using an analog meter with a needle and scale, usually does a great job of averaging these spikes, showing accurate readings of "net" voltage. Having your alternator checked is simple and usually indicates accurately whether you need a replacement. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
