The 656 has a hydraulically engaged PTO like the larger tractors. You will need the engine running to check it. Using a pipe wrench will only tell you if the PTO brakes are working.
You can see the IPTO drive gear between the pressure plate and the release bearing if you remove the bottom cover and look up there. You should be able to see if the splines are chewed up.
I once drove a nail in between the worn out splines on a tractor to allow it it be driven a couple miles to the shop. Not a good solution but it did the job. Made it more difficult to split though. :lol:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
