Posted by philip doolittle on December 01, 2014 at 06:43:16 from (50.102.253.187):
In Reply to: AM radio posted by bmagee on December 01, 2014 at 05:27:33:
Static noise on your radio can be reduced by putting a .1 microfarad capacitor on the + (positive) terminal to tractor ground. Capacitor should be rarted for at least 50 volts or higher and plastic for weather reasons. That said "Radio Shack" make noise reducers that also contain a small inducter ( chock coil) which sells as a" NOISE "eliminator. Either is not very expensive, If you still have too much noise you may find that a shielded wire for the 12 volt( maybe 6 volt) power lead with the shield ONLY connected to ground at the radio end. Hope this helps.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
