Posted by rhtx55 on December 01, 2014 at 15:59:18 from (68.191.209.251):
In Reply to: IH 3514 generator posted by undoctor on December 01, 2014 at 13:38:40:
If there is enough mica (red stuff)left between the commutator bars, carefully lower the spaces between them around a 1/32 to 1/16 of an inch with a narrowed hacksaw blade, ground to just fit the groove.
Keep them all even by counting the strokes, then polish the commentator chucked in a drill press with sand paper. Do not use emery cloth. and blow residue off with compressed air.
If the brushes have worn a groove into the commentator, a machinist can true it back up for you, then repeat the above process.
Replace the brushes with new ones of the correct grade.
Any local starter / alternator shop can re-cut these grooves for you, most have a machine designated for this purpose. Most could rebuild the generator for you.
This post was edited by rhtx55 at 16:34:33 12/01/14 4 times.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
