Posted by mkirsch on December 02, 2014 at 05:06:30 from (72.45.143.81):
In Reply to: F 200 starter posted by Darald on December 01, 2014 at 21:12:40:
The starter is sucking the voltage down on the battery, causing a weak spark, or no spark at all. When you stop cranking the starter, the voltage comes back up, momentum carries the engine through a compression stroke, a plug fires, and off she goes.
Dad's Super M started doing this after it was converted to 12V. Since it fires and runs as soon as you let off the starter, we've just lived with it.
Does your tractor have a 12V conversion with the ballast resistor installed for the coil?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
