Re: Farmall A seals
Posted by Jim Becker on December 02, 2014 at 07:34:47 from (173.84.240.213):
In Reply to: Farmall A seals posted by HenryO on December 02, 2014 at 07:17:50:
It depends on how deep you want to go to replace seals. If you change all the seals in both final drives and the ones on the sides of the differential, the answer is YES, it takes 3 or 4 per side.
The ones on each side of the differential are easily seen and replaced once the final drives are removed. There is one on the upper shaft in each final drive housing that can be seen once the brake drum is removed. If you change these, be sure to get the brake drum good and tight when you replace it. There is one on the outer end of each axle shaft. Replacing it requires fairly complete disassembly of the final drive. I wouldn't do it unless it was actually leaking. If you have a seed drive, it will have the fourth seal on that side.
There is an exploded view in the parts catalog, a manual you should have before doing much work on a tractor. An online copy can be found on the CaseIH site.
http://partstore.caseih.com/us/
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
