Posted by DR. EVIL on December 02, 2014 at 09:03:37 from (70.194.167.104):
In Reply to: Farmall 350 TA Troubles posted by Andrew Psencik on December 02, 2014 at 06:16:26:
It sounds like the little planet gears are junk. The actual shift into low range is done by a small dry disk clutch releasing & engaging, all gears are already meshing and the clutch directs power thru the proper set of gears.
I would NOT pull the TA lever back until you can get the TA replaced, and those teeth on those planet gears are tiny and fragile, bet some have sheared off, I wouldn't run the tractor much until fixed either.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
