Re: Weak spark on Cub Lowboy
Posted by John T on December 16, 2014 at 11:50:45 from (216.249.72.121):
In Reply to: Weak spark on Cub Lowboy posted by Richard G. on December 16, 2014 at 07:54:17:
"If it is 12, would that make the spark weak on a 6 volt system?"
YES If you apply 6 volts to a 12 volt coil the spark will be weak
"Also, on a positive ground system, does the hot wire from the switch go to the + or - on the coil?"
Input from ignition switch to - coil terminal and + of coil to ground (via closed distributor points) for a Pos ground tractor.
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
