Re: removing / installing dry sleeves
Posted by pete 23 on December 20, 2014 at 15:49:51 from (74.33.70.156):
In Reply to: removing / installing dry sleeves posted by heck914 on December 20, 2014 at 14:17:18:
Two things here before you start pulling those sleeves. Check the sleeve flange protrusion over the top of the block. You can do that with a simple feeler gauge and a flat chunk of iron. This is a reference to make sure the new ones don't protrude higher than old ones which has been a problem lately with new parts. Then make darn sure your pulling plate is not larger than the outside diameter of the old sleeve. It probably has thin wall sleeves already and they are only 1/16 in thick. Originals were l/8 inch t hick. You want your puller to be a few thousands of an inch smaller than the sleeve. Another thing, when you get the bores cleaned out good, try the new sleeves at same temperature as the block. They should start into the bore a little ways. I always select the best fitting sleeve for each bore. Some will be looser and some tighter. Then you can freeze them if you like, I never do because I want to know how hard that sleeve fits into the bore. Too tight, no good, too loose, no good.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
