Your description of movement sounds normal. With draft control lever on light toward rear it already pulls the valve out and with it on heavy, which is where you should leave it then the position control lever would move the valve (block you are seeing move pulls stem of valve). Make sure that when you push position control lever all the way forward into offset that it contacts the action control device and moving lever in and out of action control (offset) that valve lever pivots. The action control mechanism just dumps oil supply to slow hitch reaction time. You either have no or only slight flow from pump, unloading valve sticking in draft control valve assembly or fluid is just leaking away , looping around in valve section. You can take pipe off from hitch pump to check free flow in a bucket but if you cannot deadhead system it is pretty hard to simulate stuck unloading valve. You could put a valve in the looped hose and partially restrict flow. I just have to assume the system relief valve is still intact in the aux valve body mounting plate.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
