Whew. The first check I would make is to see if the amp meter (open to the air, and subjected to a fair load with an alternator) is still good. With the lead to the starter switch disconnected use an ohm meter across the terminals of the meter. If infinite ohms it it toast and probably 100% of the problem. If zero ohms, it is probably good. Next, assuming the above had zero ohms, Rehook the wire to the amp gauge and test the meter for voltage on both sides, once with the lights on, and once with them off. If the load side with the lights on has no voltage, the amp gauge is bad. If no different but no lights, the fuse could be blown on the light switch, or bad wiring/terminal connection at the switch. Fix that. If the ignition switch has voltage to the supply side, it should also have voltage to the ballast resistor side when on. Check to assure it does. If not correct that. Check voltage at the ballast resistor with the switch on/ If volts, test the other side for volts. no volts fix it. A three wire application of a 10si requires a 10 watt resistor across the LED style dash lamp. A LED does not supply enough current to work. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
