Look behind the carburetor for a long thin horizontal crack in the casting that weeps antifreeze or has been repaired, it is a classic frozen block syndrome. Look for cracks near the four bolts where the steering bolster bolts to the block. Look at the final drive castings for cracks and welds, especially the left hand side which take most of the weight. Check to see if the hydraulics are leaking oil into the engine base through the pump seals by cracking the top petcock on the oil pan for excess oil. Loosen the drain plugs on the engine and transmission/rear to the last thread and look for antifreeze or water. Jack each rear wheel off the ground and look for the wheel to "fall" outward, that movement means bad bearings. See that the transmission doesn't pop out of any gear. Check the brakes. Look the rear tires over, they're expensive. Only cracks in the engine block would make me think twice about buying it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
