This could also be due to excess resistance in the coil circuit.
I bought an 8N Ford that acted the same way. It had a 12 volt alternator conversion kit.
Whoever did the conversion used a direct 12 volt coil (no resistor required) but did install the resistor and the resistor measured 5.5 ohms rather than the 1.5 to 2 ohms that it should be.
I removed the resistor and it started and runs like it should.
Check to be sure you have either a 6 volt coil(1.5 ohms across small posts) and a near 1.5 ohm resistor, OR a direct 12 volt coil (3 ohms across small terminals) and no added resistor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
