Posted by pete 23 on January 25, 2015 at 20:39:09 from (173.87.13.92):
In Reply to: 450 2 point posted by BudKaiser on January 25, 2015 at 17:50:23:
If the hoses are hooked correctly, the hitch will raise when you move lever forward on a 450. Opposite of a 4 or 560. And that hitch should hold up indefinitely. Most likely the check valve block and it should be easy to repair with a new o-ring. Could be the cyl also and that is easy to test. Just take the hose off that is not holding hitch up and if any oil leaks out it is cyl leaking. Also, if hoses are hooked correctly, that hose would be the one not going into the check valve block.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
