Someone more knowledgeable will pipe in but I'd think the longer you run it the more damage you'll do. It might be terminal at this point (cost more to fix than it's worth) or it might not but the longer you run it the more wear it's going to get in places you might not want worn.
My thought process is if it's slipping
1. either fluid isn't getting pumped in the volume or pressure it's supposed to and running it with that slip in the pump is going to accelerate the wear, what might need wear plates or some machine work if run long enough will trash the pump.
2. The other possibility is the fluid pressure and volume is okay but the by-pass is in the transmission, again fluid under pressure being forced somewhere it shouldn't be will cause more wear.
Before I'd make a decision I'd recommend getting a manual and doing basic test to figure out what's really wrong, it would be bad to trash a tractor worth thousands because you didn't want to make a repair that cost hundreds.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
