My guess is that somewhere in the life of the donor tractor it had the ring gear replaced and it was replaced with the gear that was used on tractors up until the 404 series. If the ring gear is not in like new condition you can assume that the tractor was run with that ring gear not causing problems.
Check the tooth engagement of your drive in the replacement ring gear. It will most likely work just fine as long as the ODs of the ring gear is the same. The tooth engagement is pretty loose between the drive and ring gear and it s not uncommon to find a couple drives with different amount of teeth being used on the same ring gear. That is the case of drive number 1939109. That is a 9 tooth drive that was replaced with a drive with 10 teeth during the production run of the 656 tractors. There was no change in ring gear when the drive was changed on those tractors.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
