OK, does it leak while running. When you are cranking, gasoline is and has to be pulled from carb into manifold. If it does not immediately start, there will be some excess gasoline that does not make it up into engine. Slow cranking speed may be your problem. This happens on all carburetors but down draft carburetors don't show it as it goes directly into the engine. If it does not leak while standing, not running, or leak while running I say carb is ok. Also, do you have a packing in the drip plug hole. That drip plug is to slowly allow excess fuel to rid itself while shut down but if open hole gas will flow freely. A carburetor is a rather crude device to say the least as you can make an engine run by just squirting gasoline in with a oil can.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
