Re: Farmall A convertion to 12V negative ground
Posted by Bob on February 02, 2015 at 18:12:22 from (64.255.159.192):
In Reply to: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 17:58:00:
What you are doing has been done many times and does work.
The primary of the coil INSIDE the mag needs to be disconnected from the points and condenser (which presumably has already been done).
And you are correct in the power being connected to the (+) side of the coil.
You also need a "true" 12 Volt coil, or a ballast resistor ahead of a 6 Volt coil.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
