Posted by Kevin on February 04, 2015 at 15:57:25 from (174.236.6.92):
A few days back i had some farmall a governor questions. I got down to the shop to tinker with it a little. Issues are i suspect im not getting full rpm and the first half to 3/4 throttle range is no responsive. Previous owner had a spring between carb flange bolt and governor arm pulling tension on it but it would always idle high however did turn more rpm. I removed that spring knowing it is not suposed to be there and am now looking to solve the problem correctly. Tried adjusting the rod between carb and governor arm as suggested. With tractor off i removed the linkage, moved the throttle to wide open position the adjusted the linkage so the carb is in the wide open position and the pin slipped through the yoke easily to re attach the rod to governor arm. Only took a half of turn and nothing changed. Just checking if i did this right and what do i look for next?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
