Also remember we deal with multiple issues on a hourly basis. remember to tell us which engine/tractor you are working on. Coolant in the oil on a Farmall B can come from a cracked block, but it can also come from Orings at the base of the wet sleeves. At the bottom of each cylinder (which is actually a sleeve that is pushed in from the top and exposed to water on the outside) the large Orings surround the sleeve and seal it from the oil pan. These get brittle and loose resilience over years. It is quite possible this is the cause of that coolant in the water. If the external leak is behind the carb, it is common and can be easily repaired using several methods. Let us know where the leak is and we can help that issue. Keep the faith. We do, Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
