You may have seen my H carb procedure before, maybe not. THis might help;
Make sure the float isn’t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so the float doesn’t rub or touch. Pretty important. Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber. Initial settings are as follows to get it started; Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. [This screw adjusts fuel.] Idle air-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. [This screw adjusts air.] Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages in the slot. [This screw adjusts RPM’s.] Final settings are determined as follows; Get the engine warmed up, and idling. Turn OUT the idle air-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.) Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine is set at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.) Should rev up smoothly and evenly. Too Lean = stumble, sputter, damaged melted plugs. Correct = tan plugs. Too Rich = back smoke, black sooty plugs.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
