Correction my memory was off on the I-460. Checked and the I-460 unless a high utility, 504 and 340 all use the same 59 tooth sliding first gear and a 20 tooth gear driving the 59. Unless equipped with high speed first and reverse, then they used the same first gears used in a 300, 330, 350 or F-460. Ring gear and pinion counts. F-340-49&14, I-340-49&16, F-460-49&15, I-460-50&18, F-504-50&13, I-504-49&16. High clearance internationals have the same R&P ratio as the farmall models most times. Farmall models of 300 and 350 use the same ratio gears as a F-460 along with the first gear speeds.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
