Posted by IAtractorKid on February 19, 2015 at 15:21:28 from (184.97.59.87):
Hey guys! Warmed up a little today and I had some time so did a compression test finally...doesn't look good! As follows: 1 - 90 psi, soot on plug 2 - 115 psi, wet plug 3 - 100 psi, soot on plug 4 - 0 psi, wet plug 5 - 0 psi, plug looked perfect 6 - 115 psi, plug looked perfect
Thoughts?? This was a good running tractor with plenty of power prior to when it started knocking two weeks ago. At first knock was only between 1200- 1800 rpms but now its all the time. What would cause two dead cylinders like that?? Thanks for any help!!!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
