Everything looks the same in your picture, as this tractor. However, the spring is in place of the clamp for the cable, and another bracket was made for the cable.
Thanks for the advice on how long to activate the glow plug button. We were only holding in for about 30 seconds. But sitting in the shop last night, without heat on, it did start. We had 14 degrees overnight too.
As far as testing the glow plugs, I had the charger set on 2 amps, and held long enough to see some smoke coming off the glow plugs.
Does the glow plug button pop right back out, when you release it, or does it slowly come back out. This one comes out slowly, and when pushing it in, you need to push on it, as there is some resistance.
you also mentioned the timing wasn't quite right on your injector. Did you take the cover off, and reset, or did you do it running, to tweak it?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
