Posted by pete 23 on March 04, 2015 at 08:58:27 from (50.33.21.76):
In Reply to: 706 trans noise? posted by Jrw013 on March 01, 2015 at 18:58:48:
You are talking about a clunk with clutch engaged. At that point the throw out bearing should not be touching or turning unless you have no free play on clutch. You also say the noise sounds like near the clutch pedal. That would be rear of speed transmission or range transmission. I would make sure you have free travel on clutch pedal. Then put speed transmission lever between 2nd and 3rd gear which will be a neutral. No detent there so you have to feel your way. This will stop all speed transmission top shaft gear movement and mesh with lower gears while stopping all turning of range transmission. This should help you pin point area of noise.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
