Re: int super h
Posted by Red Button on January 14, 2001 at 17:28:04 from (205.188.197.167):
In Reply to: int super h posted by jonsey on January 14, 2001 at 14:27:35:
The sup H splites between the clutch housing and the rear end housing, the screws are inside the clutch housing. but you can work on the tranny without spliting go up through the inspection plate take the u joint apart remove the clutch then you can remove the in put shaft. for your other problem check the forkes and the ball and springs that hold the forks in place. and the pilot bearing at front of pinion shaft. good lock
Post A Followup
: Re: Re: int super h
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
