What I would try is make a big easy out. I know, hate that word. Take a flat piece of iron just a little larger diameter than the pipe that is broken off. Bevel the edge a little and drive it in. Not too tight so as to stress the valve body. First off though, put some lint free rag or paper inside the spool bore to protect it from crud. On the other one, I would do a little tapping close to the threads and put a pipe wrench on it. Now, the way to avoid this problem in the future is to lube those threads when installing and do not tighten it very tight. There is nothing to leak out of those threads anyway as the o_rings hold the oil. What I do when I assemble the spool is to tighten that large nut really tight onto the pipe by putting the nut in a vise and using the pipe wrench on the pipe. Then the next time you can put a socket on the nut and it will screw the assembly out easily. If you don't like using a pipe wrench on it a chain wrench works also. A rag on the pipe wrench will keep from marking up the pipe (union).
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
