Thanks Jim!!!!
Posted by 300guy on March 12, 2015 at 19:44:50 from (76.85.161.57):
Last fall I posted a question about setting the end play on the bearings on a C-24-P mower's flywheel shaft. It had shims on the cover plate. Anyway Tuesday when I was up to the farm to replace then, you said you installed the bearings and then tapped on the end of the shaft to set the bearings. It worked like a champ!! When I first put the cover on and tightened it up, the shaft would not turn. So I tapped on the end and after 3 or 4 light taps the shaft turned nicely!! So I sealed it up and put it together. Putting the flywheel on was a real pain to drive it back onto the shaft!!!!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
