The first image is of a cutout relay, not a regulator. If it was original to the generator (probable) the generator will be a three brush style. The use of the real regulator (other pics) is just fine. The wires will go as follows: the L terminal goes to the light switch fuse connection it should be 10 gauge wire. From the Bat terminal, a 10 ga. wire goes to the load side of the amp meter (side not connected to the start switch) From the F terminal a wire should be connected to the Field terminal on the gen (12 gauge works). From the Arm terminal a 10 gauge wire connects to the terminal under the base (GEN or ARM) is usual label. The third brush (in the gen) will be adjustable. It should be adjusted pretty much as far as it can move toward the fixed brush. Polarization of the generator is done by touching the Bat terminal to the GEN terminal for one second with a solid copper wire (12 gauge house solid will work). It will spark a bit, not dangerous. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
