Posted by CenTex Farmall on March 23, 2015 at 21:17:45 from (72.105.160.30):
In Reply to: found Crack in block posted by chad from michigan on March 23, 2015 at 16:49:03:
Annoying for sure but repairable. You can try the JB weld, if it doesn't hold then you can braze it. If it came to it I would braze over arc welding but an expert could do it. My luck with welding cast is about 50/50.
The trick with JB weld is cleaning the base metal. After you grind the area you want to use _acetone_ to remove all oil residues. I think I found that info on the JB website. Even some brake cleaners can leave a residue.
The second trick will be keeping the area warm while the JB cures. A heat lamp could work if you're parked inside. Then too you'll have to babysit the stuff for the first hour or so as it will want to ooze down. Not a big deal but you don't want to do it twice.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
