1 - Your voltage readings indicate the alternator is performing within specs. No problem there.
2 - Your coil is running WAY too hot. (It should run only slightly warmer than the ambient air around it.) And a hot coil means it's drawing way over design current. My guess is it's a "6 volt" coil and which is being supplied nearly double the design voltage. (BTW doubling the voltage QUADRUPLES the heat generated inside the coil).
I'm not familiar with your electronic ignition. It sounds however your coil is mismatched to the ignition. Or perhaps it needs an external ballast resistor to work with the coil.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
