Re: Re: Re: 450D fuel pressure
Posted by brianh on January 23, 2001 at 08:29:20 from (64.12.102.171):
In Reply to: Re: Re: 450D fuel pressure posted by Jon on January 22, 2001 at 14:29:16:
Yeah, there was a test adapter available that replaced the top vent in the primary filter, but I don't know where you would find one. You may have to get creative with plumbing since they are reverse compression type fittings, or maybe use hose. A good plumbing shop should be able to get you the fittings and pipe. See if the primary pump will make 32-39 lbs into a dead end. If not there is a restriction somewhere or the primary pump relief valve is stuck open or opening too soon. If the pump makes good volume of fuel but cannot maintain pressure when connected to the plunger unit then the plunger unit relief valve is probably leaking. Since you had the primary pump out that is where I would start. Make sure in your disassembly that the relief spring or plunger didn't get left out or damaged accidently, or that a piece of foreign matter got lodged in there. If you determine that it is the primary pump and you can't find the problem, a diesel shop will probably work on the primary pump by itself cheaper than sending them the whole thing and asking them to troubleshoot it. Same way with the plunger unit, but you will probably want the service manual for it before you disassemble the pump. The book is expensive,but eventually worth it if you do much repair .Contact me directly if you want further specific info.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
