Welding Basics, Part 4
Maintenance, Mechanical and "How-To" Information Simple Fixes Third-Brush Generators Oil Bath Air Filters Magneto Timing Converting Your Tractor From 6-Volt to 12-Volt Ford N-Series 12-Volt Conversion Kits (Early) How to Measure Overhaul Parts Replacing your Rings Engine Rebuild Pitfalls Engine Troubleshooting - Gasoline Engine Engine Troubleshooting - Diesel Engine Engine Valves - Some Helpful Information Two-Brush Generators Plugs & Compression Testing Secondary Ignition Wires and Distributor Oil, Oil Filter and Air Breather Cooling and Fuel Systems, Hoses and Belts The Battery The Engine Rebuild Kit What Kind of Oil Should I Use? Upgrading an Oliver Super 55 Electrical System Field Service Operations and Lubrication A Tinker's Guide to Manifold Repairs The Fordson F Ignition System The Fordson Improved Vaporizer Listening to Your Tractor, Part 1: Colors Listening to Your Tractor, Part 2: Smells Listening to Your Tractor, Part 3: Noises Listening to Your Tractor, Part 4: Bad Vibes Measuring with Calipers Tractor Generators Recommendations for 12 Volt Conversions Welding Basics, Part 1 Welding Basics, Part 2 Welding Basics, Part 3 Welding Basics, Part 4 Welding Basics, Part 5 Updating the Charging System Tractor Hydraulics - The Basics Tractor Hydraulics - The Basics, Part 2 A Step-by-Step 12-Volt Conversion Hydraulic Cylinder Anatomy Solvent Types MF 35 (and up) Tractor Assembly Notes Step by Step Carburetor Overhaul The Nuts and Bolts of Fasteners The Nuts and Bolts of Fasteners, Part 2 Torque Wrenches Wiring Basics Ford 2000 & 4000 12-volt Conversion Ford 9N, 2N and 8N Transmission/Hydraulic Fluid Troubleshooting the Ford 8N Hydraulic Lift The Ferguson System Principal Oliver 550 Purchaser Checklist Oliver 550 Clutch Overhaul Tips Adding an Hour Meter
Submitted Article
by Curtis von Fange
Links to the previous welding articles:
  • Welding Basics, Part 1
  • Welding Basics, Part 2
  • Welding Basics, Part 3
  • Oxy-Acetylene Welding - Part Two
    Our ongoing series is discussing some basics in barnyard welding. The previous article gave some introductory material on the equipment and safety factors when working with an oxyacetylene unit. This portion will try to deal with the gas welding procedure and what we can use it for.
    We've been working slowly but surely on our bushog repair over the past several months. Let's pretend for a moment that our natural talent for stick welding has surpassed all our dreams and our heavy framing and reinforcement is complete. Now we need to weld on the sheetmetal so we can wrap this thing up and paint it. But to our surprise the arc tends to melt the sheetmetal faster than the metal framework. The difference in metal thickness makes the thinner metal blow away before a puddle can be formed. Here is a great example of how gas welding can come in handy. Let's take a quick review before we start.
    Our oxygen and acetylene tank are secured to the wall, stand, or cart with a chain. The regulators are in the off position or are unscrewed all the way so no pressure is present on the diaphragm. The hoses are safely wound away from the weld-site. We have our gloves, goggles, leather wear, and safety shoes on and our uncoated steel rod is lying to the side, easily accessible within our reach. The repair has been wirebrushed and cleaned of debris and is ready to weld.
    When gas welding with thin tin like on our bushog we want to keep the pressures on the regulators quite low so we don't make a blowing flame. We are also using a smaller orifice on the torch to help keep the heat level low. In general the thin metal we are welding will require a rod about the same thickness. If the sheet metal is 1/8 inch in thickness, then we need a 1/8th uncoated rod. The torch orifice size is equated to a numbered drill size, in this case a size 54 -57 tip drill size. The pressures on the regs are low: 5 psi for the oxygen and 5 psi for the acetylene. Remember these are pressures for gas welding with a single orifice torch. Pressures for the cutting torch are different and are not for this type of repair. Remember to open the gas tank cylinders slowly to prevent regulator damage and then screw down the diaphragm adjusters to the appropriate pressure settings. It can be helpful to open the corresponding torch valve at the same time to bleed the gas in the line off and to ensure the correct gauge setting.
    Now we are ready to light up. Open the acetylene torch valve no more than 1/16 of a turn. Cup the flint lighter over the tip to collect a little gas and ignite. Next, turn the acetylene torch valve on slowly until the acetylene flame becomes turbulent a distance of 3/4 inch to one inch away from the orifice. Note that at this distance the flame will stop smoking. When proper turbulence is recognized open the oxygen valve a little bit. Note the color change in the flame and the slow development of an double inner cone within the acetylene flame. As oxygen is increased the larger middle flame will merge with the inner greenish hued cone. When there is only one lightish green/blue cone established then the flame is called a neutral flame. If the secondary or middle flame is still visible then the flame is called a carburizing flame; a cooler flame with too much acetylene is being consumed. If the inner cone is established and then additional oxygen is added it becomes an oxidizing flame. This is also characterized by a hissing sound to the torch and more of a bluish tinge to the flame. Too much oxygen will burn or oxidize the metal being welded. The neutral flame has a soft purring sound to the torch, has a well defined inner cone with the greenish/blue tinge, and is the hottest part of the flame produced. This is the flame we are looking for.
    Next step is to heat the metal we are going to weld. In the case of our bushog we want to preheat the thickest metal first. Hold the torch at a 30 to 45 degree angle to the work. The flame spreads over the work in the direction in which the weld is progressing and acts as preheater to the material. Rotate the torch tip in a circular motion for even heating and puddle control; hold the inner cone just above the developing molten puddle of metal. This motion should be contained within the parameters of the created molten puddle and not stray outside the welding area. If the puddle starts to sag or burn through then adjust the distance of the flame to the weld by increasing the angle of the flame rather than by pulling the flame away from the puddle. The molten puddle that you create with the flame is what will make the weld between the metals. When working with the different thickness of metal it is necessary to form the puddle on the thickest portion of steel and then float the puddle onto the thinner steel so as to not burn through. Adding extra metal to the puddle with a rod may or may not be necessary. If the parent steel is thick enough then the puddle may flow easily to the thinner steel and form a great weld. If additional metal is needed then the rod may be added. Move the rod towards the flame so it is preheated then place the rod end into the puddle as more metal is required. The flame will melt the rod accordingly. Try to avoid a dripping rod as this only creates a weaker weld. As with most things it takes some practice, trial and error. Take some scrap pieces to practice on before doing a finished job which will show your skill; or lack thereof.
    Here are a couple of tips to keep in mind as you weld. The appearance of the puddle will be a good indicator as to your progress. A good puddle will have a smooth, glossy appearance. The edge away from the torch will have a small bright incandescent spot which will move actively around the edge of the puddle. If this spot is oversize the flame is not neutral. If there are weld bubbles and excessive sparks then there is either a poorly adjusted flame or a poor quality/dirty metal/rod that you are working with. If the torch pops and spits then try to increase the pressures in the regulators just a little bit. The gases are preigniting and may be corrected by a somewhat higher pressure from both tanks. The tip also may become overheated by operating it too close to the molten puddle; try extending that distance. Another possibility of torch popping is that the tip may have some carbon deposits or hot metal particles in the orifice. Using a properly sized tip cleaner will open the passage back up. Avoid submerging the inner cone into the molten metal as this can create a flashback condition where the gas burns back into the regulator.
    All in all the more time spent practicing with the puddle the better the weld seams that will be produced. Take your time and slowly move the puddle forward along the metal seams making sure the circular motion of the torch is consistent. Heat control by this method ensures that the puddle will not grow out of hand or that a burn through will result. With a little practice one will find that this type of welding is real handy when working with thinner metals because it offers quite a bit of creative control in the weld.
    In the last installment of this series we will give some tips and instruction on using a cutting torch.
