Heyall,
I posted a few weeks back when I was trying to get my new to me WD running. Since then it's undergone paint and working out gremlins.
Now I am pulling out what's left of my hair due to a carb issue.
I cleaned and rebuilt the Marvel Schebler carb. I was having issues with the fuel bowl overflowing, which ended up being a leak around the base of the float needle seat. It ran fine, but leaked when parked. I mowed 5 acres of pasture, did a bunch of joy rides, that kind of thing without any issue otherwise.
Yesterday I took the carb apart, and torqued the seat down snug and was able to get it to stop leaking. Also re-checked for crud, and everything is clean as can be. I reset the float level, and now the carb isn't dripping.
So I jumped on the tractor and drove it half mile down the road to my dad's farm, picked up my snow blower, drove home, and parked.
Today, so far we have a foot and a half of snow, and I decided to move some of it. First thing when the tractor started, it was barking and popping from the exhaust. Adding choke didn't help. I backed it out and let it idle for 10 minutes while I did other things. Trying again to move snow with it at full temp, and it would start to die within 30 seconds of starting to work, bark, pop, done. Wait for 30 seconds, and it starts right up again.
Back in the shop, I put the clear fuel line on the carb bowl drain and checked the float level. With the engine off the height is perfect. At an idle, it drops to about the 2/3 mark, and as soon as I move it to half throttle, it drops right to the bottom and starts running lean. Whacked the carb a few times in case the floats were hung up, without success.
I ran the drain line into a cup, and it is running full flow through the tube.
Anything else to try? Certainly seems like a supply issue, even though the supply seems to check out. And it was perfect yesterday! But using the clear line, I can prove that the bowl level is dropping too low. The only difference between yesterday and today, is that today they are calling for 3 feet of snow, and I need the tractor!
Thanks all.
Thanks all.
